Hello again,
Before i make a mistake, I think its best i ask you guys.
I just put new tires and had and an alignment done,
The ride height is OK.
The guy at the shop showed me the the right front wheel will not align, he adjusted it to the max(the 2 nuts) and still the bottom center of the tire kicks into the car. Maybe 1 or 2 degrees, i cant say for certain but if you look at both tires you can see the right tire is at a little angle.
I would like to fix this, but what would you recomend, At the tire shop they told me to go and see this guy who will put it in some kind of a Jig and with hydralics pull the bottom of the tire out.
That sounds pretty rough on the 66. I dont want to cause a bigger problem. Anything you guys can recomend will be great.
Regards,
Andrew
