In the Fires of Hell.....
Sounds like a different issue for you.
This one happens while at the end of a long right hand turn, or exiting that corner. Not on braking. It also tends to happen at around 1/2 a tank or less.
You may be losing some electrical connection while hard on the brakes... I doubt it is fuel, more electrical, possibly leading to fuel.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
