-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/forumdisplay.php?f=225)
-   -   First Issue (http://forums.pelicanparts.com/showthread.php?t=332183)
lambic2000 02-24-2007 12:53 PM
First Issue
Well, I have my first issue with the 2001 325xi to deal with. I noticed when I first got it that the carpet on the front passenger floorboard was a little damp and thought it was the result of the quick detail the dealer performed prior to me leaving the dealership. Now that we have had a real good rain here in Newport, there is now standing water in the same area.
I expected this out of my 23 year old Porsche 944 but not a 6 year old BMW. I have no sunroof.
What could be the problem and how can I stop it? Thanks!
Stephen
Jeron 02-26-2007 12:08 PM
The most common cause would be the vapor barrier in the door was not replaced properly after a repair. Probably a window regulator replacement.
Search the web for "e46 vapor barrier", "e46 water floor"
TDHarris 09-27-2008 03:43 PM
Stephen,
I just developed the same problem in my 2001 325xi. Major water on front passenger floor, and a small amount on driver rear floor. What was the cause in your case, and how did you go about fixing it?
Thanks in advance,
Tom
chuka 10-20-2008 11:12 PM
hi!! I've had this problem previously. the problem was that the a/c duct drainage had shifted out of position and thus a/c water was drainning into the car and not outside it. had to have it readjusted to the correct position to solve the problem. hope this is helpful. Cheers!!
TDHarris 11-10-2008 06:36 PM
Passenger Compartment Leak - Update
I've located the leak on our 2002 325xi. The moisture barriers on all 4 doors came unglued along the entire bottom edge. The moisture barriers are held on with what appears to be some type of rope caulk, not glue. It is disappointing to see such shoddy materials used on a BMW.
Tom
Rot 911 11-12-2008 06:11 AM
Tom, actually the rope caulk works better than glue as it doesn't dry out over the years.
