Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
First Issue
Well, I have my first issue with the 2001 325xi to deal with. I noticed when I first got it that the carpet on the front passenger floorboard was a little damp and thought it was the result of the quick detail the dealer performed prior to me leaving the dealership. Now that we have had a real good rain here in Newport, there is now standing water in the same area.
I expected this out of my 23 year old Porsche 944 but not a 6 year old BMW. I have no sunroof.
What could be the problem and how can I stop it? Thanks!
Stephen
Old 02-24-2007, 12:53 PM
Jeron's Avatar
The most common cause would be the vapor barrier in the door was not replaced properly after a repair. Probably a window regulator replacement.
Search the web for "e46 vapor barrier", "e46 water floor"
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-26-2007, 12:08 PM
Stephen,
I just developed the same problem in my 2001 325xi. Major water on front passenger floor, and a small amount on driver rear floor. What was the cause in your case, and how did you go about fixing it?
Thanks in advance,
Tom
Old 09-27-2008, 03:43 PM
hi!! I've had this problem previously. the problem was that the a/c duct drainage had shifted out of position and thus a/c water was drainning into the car and not outside it. had to have it readjusted to the correct position to solve the problem. hope this is helpful. Cheers!!
Old 10-20-2008, 11:12 PM
Passenger Compartment Leak - Update
I've located the leak on our 2002 325xi. The moisture barriers on all 4 doors came unglued along the entire bottom edge. The moisture barriers are held on with what appears to be some type of rope caulk, not glue. It is disappointing to see such shoddy materials used on a BMW.
Tom
Old 11-10-2008, 06:36 PM
Friend of Warren
Tom, actually the rope caulk works better than glue as it doesn't dry out over the years.
Kurt V
Old 11-12-2008, 06:11 AM
