I have a 2000 BMW 328i. It's been running really cold in wintertime temperatures (40 degrees) or lower and especially on the highway so I decided to replace the thermostat. I started my car up today after the replacement and noticed the temperature gauge climbed to the middle in about 5 minutes. That's a definite improvement. What's troubling is I get no heat from the vents when the car is warm. I did before I changed the thermostat. Any ideas on what I can do?
It is almost certainly air in the system. You need to continue to fill and bleed the system with the heater set to high.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Thank you. I will try that today and post the results.
That did the trick! I got heat pouring out of those vents now. Thanks again!
Glad it worked. That is by far the most common cooling issue.
Having same kind of heating/cooling issue as last person posted??
2000 BMW 328i blows out cold air out of heater, and coolant residue is
blow into the interior and on to inside of window. when i turn the car off it is lugging like a desiel truck. i have had therm, heater core check and there alright. please help, totally stumped???? |
| Tags |
| 328i , cooling system , no heat , thermostat |
