Guest
Posts: n/a
help code p1634 please
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Reading BMW Fuel Injection Fault Codes |
Generally the code refers to: P1634 throttle valve adaptation test failed. Not knowing your vehicle type I cannot be mroe specific.
- Nick |
My generic BMW list show that code as
P1634 Throttle Valve Adaptation; Spring Test Failed If you decide that a cleaning might help, don't force the throttle valve open with the power off. Plug it in and have someone turn on the key and press the gas pedal so you can spray cleaner on it while it is open. |
