Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Rear Clunking sound
Hi,
I have a 2000 328ci and I am experiencing a clunking noise in the rear of my car whenever I accelerate normally and also when I ease off on the gas. If I am driving 20-30 mph in the city and I let off the gas, I hear a clunk. When I accelerate normally, I hear a clunk. If I try to accelerate very slowly, I can get by without hearing the noise. I have heard that there is a known issue where the transmission output flange can be replaced using the below kit. Not sure which is the good part number now.
24 21 7 515 388
24 21 7 568 563
Can you please help me confirm if this will fix my issue? If so, I figure I can also replace the guibo as well. Are there any other parts that might benefit from being changed as well if this is the issue?
Albert
Old 04-10-2014, 09:53 AM
mrehrer's Avatar
Might want a quick under car inspection to confirm it is not an issue with the subframe. The E46s also had a few of these tear out and finding it sooner rather than later would be good.
Old 05-04-2014, 11:56 AM
Tags
clunk , flange , output , rear , transmission
