Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Brake and ABS faults
Hello. I'm having problem with brake and abs faults. Changed all brakes and sensors, all abs sensors and the fault lights are still on. Diagnostics are detecting a CC-ID-24 code. Anyone know what that means? Comments greatly appreciated. Thank you.
Old 09-14-2020, 03:45 PM
Hi, I am having the same issue, code 24 is DSC which is your abs plus other.
I am just starting the sensor route keeping fingers crossed.
have you checked your sensors for resistance and voltage, google it there's heaps of info out there! If your sensors are OK then it could be your ABS controller $$$ but apparently you can get them rebuilt.
Old 01-22-2022, 05:48 PM
Follow-on from last post it was the 2 front sensors so I guess I was lucky there
Old 02-06-2022, 06:45 PM
