Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Car won't start (before and after fuel pump change)
Hello, everyone. My 2006, 325i won't start. When it happened initially, I thought it was the fuel pump cause I had it happen in my previous bmw around same milage. I bought and installed a new fuel pump, but still won't start. Instructions said to drain because of high pressure, but I didn't. Otherwise, the spark plugs are dry so fuel has not been getting to them. Any ideas what it could be? Any help is greatly appreciated. Thank you.
Old 12-23-2024, 04:58 PM
did you replace the fuel pump relay along with the fuel pump? always a good idea to replace both at the same time.
Old 01-11-2025, 01:46 PM
If the spark plugs are dry, the issue is likely with the fuel delivery. The fuel pressure sensor or injectors may be faulty.
Old 03-28-2025, 03:10 AM
