Guest
Posts: n/a
I need to replace the water pump on my 2006 BMW 330i, where and which part do get this from? I've already replaced thermostat but the car is still overheating and the fan sounds super loud when using the heater. Any advice would be greatly appreciated. Thx!!
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
A 2006 model is an E90, this tech article will help you with replacing the water pump: http://www.pelicanparts.com/BMW/techarticles/BMW-3-Series-E90/WATER-Coolant_Pump_Replacement/WATER-Coolant_Pump_Replacement.htm
Be sure to bleed the cooling system and top it up. - Nick |
