Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Ivan (guest)
Guest
Posts: n/a
I have a 2012 335I Convertible and I recently did some body work and I had to put the top 1/2 way down to put the belt molding on, i had the door glass out at the same time and now the top will not go back up, and the door glass regulator will not work either. Thoughts? Thank you, Ivan.
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-17-2014, 05:34 AM
Nick at Pelican Parts's Avatar
I don't think the to are related, unless of course fuses are blown or wiring was damaged. Are the door pin switches working (interior lights go out when door is shut)? I would check the vehicle for fault codes, as there are likely some stored.
- Nick
