e90 guide-rod and upper control arm replacement
I recently purchased the TRW/M parts that replace the factory steel links for the rear suspension - BMW E90 Rear Upper Control Arm Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
However the installer was unable to get the bolts to seat. The threads are fine and the bolts run thru the holes as long as the rod is not in place. When an attempt is made to tighten up either bolt on the outside (spindel mount), the bolt binds up. All of the PNs are correct. These are factory parts that are used on the M3 rear end. Any idea why this is not working and what to try? Even trying to back out the bolts now cause them to bind. These are the specific PNs Upper CA - wishbones Left - 33322283545 - JCT1428 right -33322283546 - JCT1429 Guide-rods - Left - 33322283547 - JCT1430 Right -33322283548 - JCT1431 |
Were the bolts tightened with the suspension on the ground / fully loaded on a flat, four-post lift? If not, then you will have issues, I believe, similar to the ones here?
-Wayne |
They never got tightened at all. The just locked up before even bottoming against the arm.
He started them hand tight, and then they would just freeze. And g/l on tracking down your vehicle. Actually, since I submitted the topic, I managed to find out the threads in the hub were basically cross-threaded. But even when the install was attempted on a lift, the rods would not line up but for no obvious reason. |
| All times are GMT -8. The time now is 11:19 PM. |
