Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Trans Program
Hi guys can somone please help me, this light came on "Trans Program", can anyone please help me out with this and what it means, and how to repair. oh yeah it a 92 525i...................
Thanks in advance Floyd
Old 10-24-2007, 08:01 AM
Dueller's Avatar
I had that come on in my 92 525i. Trans went into default mode staying only in high gear. I stopped, turned car off and it came back on. I switched to manual, shifted manually to get it home. Turned it off, restarted and it came on again. I shut it off and disconnected the battery and it apparently reset. Hasn't been on again.
Old 10-24-2007, 01:16 PM
Jeron's Avatar
1) Try the reset but you may need to hold the + and - cables together of 15 seconds to clear all memory.
2) check for damaged wire on the tranny or leaking
3) change the tranny fluid and filter
4) take it to the dealer or a well equipped BMW shop that can pull tranny codes
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-24-2007, 08:13 PM
hey Jerron I appreciate the help, but u be more specific regarding the + and - cables, ie battery cables with the battery still connected or not or just the+ and - cable witout battery, pleeeze help
thanks in advance
flojo
Old 10-28-2007, 01:07 PM
Jeron's Avatar
Touch the cables together while completely disconnected from the battery. It is basically the same as holding down the reset button on your PC, it discharges volatile memory.
Old 10-28-2007, 07:21 PM
