Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
R1100S Dying Intermittently - What Possible Causes
New fuel pump, Petrol gauge, hoses, tank clean.
When put back together, it started right up, sounded perfect.
Took for a trial run, made it around 28 miles away, then it dies. Spring break traffic flying endlessly by. Fuel pump not making any noise. Then around 15 minutes later, I turn the key and hear the whirring of the pump, and bike starts up. So I turn around, and almost make it back home. But it has to die one more time... So, sat on side of road for around 10 more minutes, then turn key, pump whirrs, and I make it home.
At first I was placing blame on the fuel pump?? But started thinking, could a bad ignition switch cause this? Are there any electrical parts that might heat up and fail intermittently?
Any ideas? I mean it could be the fuel pump, but seems unlikely, as the first one did die and this was the replacement they sent me. On the other hand, it could be a bad batch of little pumps?
Thanks!
New on bottom, old on top with decayed wiring...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 04-03-2021, 02:31 PM
How’s the battery? Mine behaved in a similar fashion, replacing the battery cured it.
Old 04-03-2021, 02:54 PM
Talk Less, Say More
ckcarr's Avatar
Had not even considered that since the starter turned... But, you might be onto something.. 04/20/15 battery. PC680
There's no feeling quite like having the bike suddenly stop all functions...
cRaIg CaRr
Old 04-03-2021, 06:03 PM
When it dies, do the lights stay om and engine just stops? Or do the lights shut off too?
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 04-03-2021, 06:08 PM
Talk Less, Say More
ckcarr's Avatar
I wish I would have looked but I didn't.
The bike is in the garage now and has been on the battery tender for a couple hours and yes, the fuel pump energizes... And it starts.
I wonder how independent everything is, the fuel pump, lights, starter... Like the starter might turn but not enough to turn on the fuel pump? That seems a little weird, but seems the pump is OK.. Since it's running. Unless it gets tired and takes naps...
I should probably replace that battery anyway. Since it's six years old, and maybe sat in a warehouse for a couple more.
I had forgot how much fun that bike is!
cRaIg CaRr
Old 04-03-2021, 06:22 PM
Check the fuel pump fuse also.
It might be fuse number 2 depending on what year
R1100S.
Old 04-03-2021, 11:32 PM
Bad kill switch or wires? There was a batch of bike that had problems because the wires to the handlebars were overtightened at the factory. I'd also take the housing apart and see if there is corrosion on the switch components.
Bad sidestand switch? Easy enough to jump.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-04-2021, 03:29 AM
Since it happened right after you replaced the fuel pump plate. I would consider the connection to the fuel pump inside the tank and the fuel pump connector outside the tank. Maybe one or the other has a defective pin or one that's not making good contact with its mate.
Old 04-04-2021, 04:42 AM
Plenty of info on here already to check, the fact it starts after the bike has been standing...breather pipe clear? Vacuum in the tank, or as a quick fix try riding with the filler cap open.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 04-04-2021, 08:32 AM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Is there a relay for the fuel pump? Pretty sure there isn't on the 11?
Mike
'07 R1200S
Old 04-04-2021, 09:32 AM
Good suggestion.
Yes there is a fuel pump relay .
The Haynes Manual said it's on the left hand side, second from the rear.
So, on the left hand side, first from the rear is the Turn Signal Relay.
Then, second from the rear is the Fuel Pump Relay.
2004 R1100S
Old 04-04-2021, 10:55 AM
unsafe at any speed
wswartzwel's Avatar
How much would you take for it today?
Bill Swartzwelder
Old 04-04-2021, 12:38 PM
Talk Less, Say More
ckcarr's Avatar
It's very shiny!
And they'll be collectables someday too!!
cRaIg CaRr
Old 04-04-2021, 03:50 PM
Brent
classic clogged fuel tank vent.
try opening the filler cap see if it runs again.
Old 04-05-2021, 07:14 AM
Talk Less, Say More
ckcarr's Avatar
You may be onto it too Brent.
I did open the cap while sitting there, and then it did start back up after sitting a bit. Could be that my internal hoses are too long and kinking somewhere?
cRaIg CaRr
Old 04-05-2021, 07:57 AM
RBMann's Avatar
In normal operation the fuel pump is triggered by the key being turned on and runs for a few second. After that it requires a signal from the Halls sensor that the engine is actually rotating. if you don't hear the pump when you turn the key on it rules out a vacuum lock in the tank.
Start by replacing the fuses, easy and cheap. There is one on the left side that powers the fuel pump. Remember TOR 2011? See post #416 and #430.
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/583441-2011-top-rockies-rally-7-28-7-31-a-21.html
I am also a fan of Halls sensor failure. The fact that it works after cooling down has been electrical problems for me.
Good luck.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 04-05-2021, 10:19 AM
I see you
flatbutt's Avatar
Any verdict CK?
Old 04-19-2021, 08:11 AM
Talk Less, Say More
ckcarr's Avatar
No verdict because it starts right up now and say's "ride me!" and I need to ride for a while until it fails. Which means I get stuck somewhere and it will say "Oh, sorry... I'm tired".
Starting to think I'm putting off a strange aura that's creating mayhem. Because then I took my R1200S for a long ride and suddenly a "brake failure" light came on.
Then suddenly my Pioneer Elite SC 07 system now keeps turning off whenever I turn the sound up, it just started that two days ago. What good is it if I can't crank up the volume?
And then yesterday went Jeeping way out in the middle of nowhere by Hanksville with a friend and got a flat. I've never had a flat in 20 years here....
cRaIg CaRr
Old 04-19-2021, 09:30 AM
RBMann's Avatar
All three of my F650GS failures happened within 50 miles of Grand Junction. Maybe that aura has moved west.
Old 04-19-2021, 09:33 AM
duda's Avatar
I think
Fuel Filter!
a young mind trapped in an old body
KTM SM-T
I ride
nuff said
Old 04-19-2021, 10:50 AM
