Fpalbrecht
R1100s Lazer exhaust question.
Guess it's spelled Laser. Was out for 4-5hrs a few days ago and about half way through the exhaust got much louder and the bike didn't run as good. Rougher idle, couple of hick-ups.
Ran perfect before I left. Doesn't look like the Laser exhaust is repackable. No exhaust leaks. Any ideas? Sent from my SM-G981U using Tapatalk Last edited by Fpalbrecht; 07-13-2021 at 08:52 AM.. |
Registered Agitator
Interesting as I've had one on mine since 2006-7 with no problems. I don't ride softly & haven't noticed any real sound difference. Do you also have the Laser chip? I'd be looking at something going out of tune or adjustment; plugs, timing, sync, valves? How many miles, year & do you have repair/service records? They're not repackable as far as I know.
Fpalbrecht
Sent from my SM-G981U using Tapatalk |
Registered Agitator
Being an '04 I'd start with checking the stick coils as they seem to be infamously lousy. Other causes could be burnt valve but you don't have many miles or maybe a valve adjuster backed off, HES is dying, have fun.
Fpalbrecht
Been Nowhere Done Nothing
Do you have a 911?
05 R1100S BCR, 04 R1150R 16 S1000XR, 24 S1000RR, 21 Ducati 950S |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Maybe you just blew an exhaust seal.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Fpalbrecht
Plugs all look great. Doesn't seem quite as loud today. I think I'll balance the TB's.
Fpalbrecht
The pipe is the 2-1-2. All connections from front to rear seem tight/sealed. The exhaust on left(as you look from behind) has a bit more pressure, and is a tad louder than the right. But it's a straight line at the end as a pose to the turns the other side makes. I think that's how it was before.
Fpalbrecht
Cleaned the air filter, adjusted idle, synced the throttle bodies. Much better now.
Ride the bike for the next two weeks and check again..it will need re-syncing again...that’s the way it is.
Frankly there are so many mods that can be done too this bike that can drag it into the 21st century the list is endless...including 1200 injector jets, do a search they are another game changer.
XR1000 K1200r Sport XT660 Tiger 955 R1100s |
Registered Agitator
Not necessarily true Chris. I hadn't synced mine for quite awhile before installing the 1200 injectors & just riding it for a month or so. I finally decided to check the sync seeing as I'd replaced the injectors & found they were still just fine even with the swap. Truly only check them once a year or so & even then they're barely off if any. My bike doesn't sit long, I ride often & switch between 3 bikes constantly.
Fpalbrecht
![]() Sent from my SM-G981U using Tapatalk |
Is your lever arm standard or short??
Color scheme looks great, never seen it before, very nice.
Fpalbrecht
unsafe at any speed
Those torque arms were sold by Pirates Lair. they are the shorter version that raises the rear of the bike up a bit. Here's an old thread.
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/299840-shorter-torque-arm-no-centerstand.html
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Fpalbrecht
![]() Verholen arm
