HP2 Quick Shifter
I'm starting to have some problems with the quick shifter on my HP2.....at least I think that is the problem?
Sometimes during a shift, the bike hesitates like the ignition has been cut out longer than what it should be when using the quick shifter. This happens intermittently while both using the quick shifter and while shifting normally with the clutch. On one of the other forums I am on, someone recommended a reset for the quick shifter by turning the ignition on for 2 seconds, then off, repeat 10 times, but I have not tried this or found any more info on this as a reset?? Anybody have any ideas or come up against this problem? Thanks
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
Jersey Boy In Texas
Try it. Then you'll have your answer. You have nothing to lose.
' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' '' ' ' ' John Filak Dallas, Texas |
I’m in the middle of a service on the bike, going to check the service disc for any info and give it a try if I don’t find the info.
Cheers |
