how to clean a helmet?
How do you guys clean the inside of you helmet?
Old 06-21-2004, 09:18 PM
fastfrank
Guest
Posts: n/a
The Shoei XSP's internals are all removable, so I remove them and wash them by hand, dry them with a hair dryer and re-instal them into the helmet and it is like new again.
If you have a helmet that has non removable lining, like most helmets do, I am not sure if you would do any damage by immersing the whole helmet in warm soaping water and brush the inside and scraping the scum out??
Everytime that I clean mine I am amazed with how nice it feels and smells.
Cheers,
Frank
Old 06-21-2004, 10:46 PM
lost sole...
Yes, you can immerse the whole thing in water and scrub it out with Woolite or something similar. It doesn't harm it but it will take several days to air dry. I usually turn it on it's side and direct a fan into it.
www.gregorhalenda.com
Old 06-22-2004, 05:57 AM
repoe3's Avatar
wow, i would never have considered dunking the whole thing...
repoe3
I couldn't repair your brakes, so I made your horn louder.
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 06-22-2004, 06:02 AM
motoyoyo's Avatar
I have used Woolite like sakurama said. I mixed some Woolite in a bowl of water and saturated the inside of the helmet with a washcloth and scrubed it really good. You can dunk the whole thing in water since the hard foam is closed cell and won't hold the water in. I used a kitchen sink sprayer and worked the water in spraying upward into the helmet. Be prepared to get shot in the face a couple times. I set the helmet near a gas fireplace for a day or two to air dry.
You can also buy helmet cleaning products like this http://www.proclean1000.com/helmet.htm , but I think it is used the same way and may leave a scent behind. The Woolite cleans really well and leaves the helmet smelling like new.
Scott
'98 R1100S - Triple Clamps, 10mm Shortened Telelever
2013 KTM 990 SMT, 2008 KTM 990 SDR
Old 06-22-2004, 07:27 AM
Kam Kam is offline
febreeze anyone???
Seriouly, I do use this stuff on my helmet and lederhosen. I couldn't find anything on the Arai website about immersing the helmet, although theoretically I guess it should be ok... Any Arai dealers out there with some info?
Kam
'01 R1100S going bye bye for an 06 1200GS, '02 aprilia RSV mille R, '03 tuono R, Kelly's bar&lounge
how about never, does never work for you???
Old 06-22-2004, 08:52 AM
Moybin's Avatar
As far as immersion, I'd be a bit leary because we don't know what kind of glue they used to hold things together. It might be hot glue or solvent bases, and water would be okay. Or it might be white glue and your helmet innards would just fall out.
Febreeze and a damp sponge get my vote.
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 06-22-2004, 09:03 AM
arbik's Avatar
Send a message via AIM to arbik
I use rubbing alcohol, with a small piece of cloth, and just concentrate on the dirty areas. then I do the whole helmet.
The way I see it, its the best stuff to use, since it evaporates, and leaves no residue. I dont want the residue of some detergent in my head when I"m sweating..day after day.
-arbi
2004 R1100S-BCP - RIP (2-1-04)
2004 R1150R Rockster; NASA approved
Old 06-22-2004, 09:47 AM
I was thinking of using a helmet cleaner like Motorex foam spray, work it in with a sponge and use a vacuum so suck the BO and crud out.
I have a Shoei X11 so I'll look into removing the liner as fastfrank suggests.
Old 06-22-2004, 09:58 AM
Roger Justus's Avatar
A product I have used and like for funky helmets, especially those with non-removable inners is MOTOREX Helmet Care. It is a cleaning foam and deodorizer that you spray into your lid. Let it foam up briefly and wipe off with a dry cloth. Does away with helmet soaking and scrubbing and dries very quickly so you get a clean lid back on your head fast. It is about $10 at your cycle shop.
Roger
Dunking your whole helmet is not a good idea acording to Arai. The use of any type of solvent (alcohol) is not recomended either. The only thing they recomend is a mild soap and water solution and a sponge(shampoo is good) or a comercialy avail helmet cleaner(motorex). All parts of the helmet are to be air dried, no heat not even from a hair drier.This info is from an Arai rep who taught me how to fit their helmets. As far as other brands I dont know.
Just shut the F*** up and ride/drive the thing.
Old 06-22-2004, 03:45 PM
I like to keep the inside of my helmets clean and have often used the 'dunking the whole helmet' method. I use a very mild wool wash (leaves a very pleasant aroma) and tepid water. I soak for about half an hour and rinse thoroughly in warm water.
I have had no problems with Shoei, BMW Systems 4 and Shark. My next helmet will definitely have a removable liner.
Cheers
TREVOR
1998 Red S
You are never too old to have a happy childhood!
A Throttle works two ways - only one is FUN!!
Old 06-22-2004, 03:51 PM
Raven's Avatar
I think your statement is the most accurate. Mild soap and water is the only to go.
I use a skull cap (Harley looking kinda thing) and wash it real regular. Almost like having a removable liner in my RF900.
Old 06-22-2004, 04:29 PM
bbq_duck's Avatar
Send a message via Yahoo to bbq_duck
repoe3
But remember to remove the helmet from the users
head *BEFORE* dunking
Cornfed - Easy Duckman, I know over two hundered ways to kill a man.
Sherry - You could glue an open jar of rats to his face, then blow torch the other side of the jar so the rats have to eat their way out through his face.
Cornfed - Two hundered one
2000 R1100SA
2004 FORD F350 4X4 DIESEL CREW
2000 JEEP CHEROKEE
1985 911 CARRERA TURBO-BODY
1985 HONDA XL600R
Old 06-22-2004, 05:41 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
I just use my kenmore washer and dryer.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 06-22-2004, 06:08 PM
buckmontana's Avatar
I never wash my helmet or my underwear.
I ride.
Old 06-22-2004, 06:24 PM
Dale Flowers's Avatar
Woolite in a dish washer with the upper rack removed. I read that it in a mag within the last year but have not tried it yet.
'99 R1100SA, ;06 DR650, '84 R100RT
Old 06-22-2004, 06:32 PM
Moybin's Avatar
You guys are scaring me, and I don't know which one scares me the most.
Old 06-22-2004, 06:47 PM
repoe3's Avatar
no wonder i was having a hard time...half the time it stuck up my a$$ and then to try and dump the whole thing was hard to envision.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 06-23-2004, 04:26 AM
Believe it or not - this is what I have done and it works great. Bear with me. Take a shower with it! Seriously. Just wash your hair - put the helmet on and squish it around. Then rinse it off. Works great and it's easy. And you get two things cleaned at once - you and the helmet!
Old 07-12-2004, 07:46 PM
