...elica rossa...
…how to mess-up your R12S pipes and cat in a few simple steps…
![]() …this little wish of mine was a set of pipes without a cat. … …but no brand (Laser/HPE/Remus etc.) would fit properly in combination with the belly pan… …so ; this is what I did… …last week I bought me a set of brand new, original pipes, got me a few Dremel ‘Heavy Duty Cut-Off wheels’, and gave me an hour (or so) in the garage in order to let the cat out… …I could only be a very simple job... ...I thought… …but that cat was somewhat bigger than I expected to be… …I honestly thought : ‘cut off that chromed top, and throw that cat away… …but you can see it in picture # 2 ; there is some sort of (a very tough !) inner shell, and that inner shell is firmly welded to the outer one… …so, I took another few of those Dremel cut-off thingies, and cut that inner shell in half… …and from there it isn’t that hard anymore… …I’m half way, and with the cutting and such, it took my some 2 hours to come this far… …BTW ; you can still see the other half of the inner shell, and I will leave that half where it is (because it is welded to the outer one, as I mentioned)… new set of pipes. I will keep the ones that came on the bike as a spare ![]() top of the cat’s outer shell is already gone (and I was surprised to see this inner shell) ![]() ![]() half of the inner shell is gone too ![]() ![]() yes, yes, yes, half of it is gone... ![]() …I’ll keep you guys posted regarding the final result…
Have a nice day ! Ron. R1200S + R1200RT Last edited by RoLoo; 02-16-2009 at 01:02 AM.. |
Underwater basketweaver
Correct me if I'm wrong, but aren't the metals inside a catalytic converter highly carcingenic. If so, I hope you are using proper ventilation and air filtering for your lungs.
'05 R12GS '08 HP2 Sport '16 GT4 |
I thought that the metals in the cat were Platinum, myself. Not sure if it's mixed with anything else, though, other than all of the carcinogenic crap that's spewed out of the engine into it.
If that's all platinum leaf, it would be nice to be able to melt it down and sell it at market value by the ounce, but I'm about 90% certain that it doesn't really work that way...
J.J. Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks. Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST |
No, not all the metal in a cat is platinum. If it were, then it would be worth several millions of dollars, considering that 1 ounce of the stuff is about U$D1000. They bond minute amounts of platinum to other metals, but I'm not sure what kinds.
unsafe at any speed
Um ... a hammer and a big punch poked up the tail pipe, will shatter that stuff... then pour it out. no dremel needed.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
unsafe at any speed
And ...........you guys worry too much about carcinogens... Go smoke a few cigars and that will clear that platinum right out of your system.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 09-17-2008 at 04:00 PM.. |
Living on borrowed time!
I think he should take that platinum into Amsterdam and trade it for some 'AK47' at the nearest coffeehouse (pronounced cough-ey house
)Rick Steves said the AK blend was the best at one of his seminars...
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
) I hear that the motorcycle cats are not ceramic based because of the severe vibration from a typical MC engine (go figure) so the honeycomb is made of nickel (as seen in RoLoo's photos). Not sure of the catalyst mix but would guess they have figured a way to plasma spray cerium oxide with parts per million levels of Pt and Pd on the surfaces to act in the same way an auto unit would...... Brock
I sure do feel a lot more like I do now than when I first got here...... 2016 S1000XR,2001 R1100 SA: Wunderlich Seat, Staintunes, Wilbers F/R 2004 MV Agusta Brutale S 1973 BMW 2002 Touring tii, '12 LR4, 86 Mondial 3.2 QV, 02 996 Turbo |
And the objective of all this time/expense is...?
- Mark |
Dismembered
Interestingly, RoLoo's cutaway shows anything but a honeycomb structure. RoLoo, have you examined the catalytic insert more closely? Can you say anything about the support structure those curly bits are attached too?
farkled '04 R1100S SOLD! 2012 Ducati Multistrada Pikes Peak (#072) "It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams |
No try, do or not do
Ron I hope you didnt pay too much for those pipes, because you could have bought a Remus header pretty cheap.
2017 R1200GSW Rallye Shreddr Signature Model |
I wanna Live 'til I die!
They are already destroyed in his picture and from that angle you would not see it anyway, as it is flow-through and not up and down in the cat...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
Brock, thanks for the info. That was a fun jaunt up there... boy I miss my old bike. I'll have to stop by again some day.
I did all that to a K12RS pipe a few yrs ago.
Cat chamber was 2 layers thick also, with a layer of perf metal and steel mesh (think steel wool) between the layers. Once inside the chamber I found 2 separate cats for cyls 1/2 and 3/4. There was not perceptible gain in performance, exhaust note is very slightly more 'throaty'. My main goal, other than just to 'know how', was to get rid of all the heat that the cat held in the chamber directly below my gearbox, I HATED hearing that thing creak and pop with heat, and having the muffler canister boil spit 15 minutes after the bike was shut down. MUCH COOLER now.
Mike Kelly Triple M Engineering Triumph 900 Thruxton KDX200 |
...elica rossa...
...and I 'need' the original shape of the pipes in combintion with the belly pan, that is the reason why I didn't bought a set of aftermarket pipes...
Have a nice day ! Ron. R1200S + R1200RT |
...elica rossa...
...BTW ; I 'made' those curly bits, in order to remove that metal cat. ...
...elica rossa...
...I can hammer all day on that thing, but it's a (very tough, and firmly welded) metal cat, not a ceramic one...
Ron-
What type of floor covering is that? RB |
...elica rossa...
...just plain simple (office) carpet...
