Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
![]() If not, return to Paonia...
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
unsafe at any speed
The average lurker only attracts the resident Wise Asssses.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
unsafe at any speed
I'll have another
I'm starting to figure out how this forum works ... knowledge is power, right Sen-se?
![]() ![]() While I have your attention, however briefly that may be, is this much metal on the tranny mag drain plug normal with 7K in miles? ![]()
JY "I love twins!" ![]() |
unsafe at any speed
Yes normal... small bits are OK.... large bits with readable casting numbers on them are not OK.
unsafe at any speed
Nice nails BTW... Manicured??
I'll have another
With all the wrenching I did tonight, I almost forgot to share a couple PM's I got from jweicht who as I mentioned earlier seemed to have similar symptoms to what I experienced. Here's his first reply to my request to share more details of his experience and what he did to fix it:
His response: Quote:
Note that despite what I believe to be good advice from jweicht regarding simply changing the slave cylinder and monitoring periodically, I decided that I had the bike far enough apart already that I might as well do a spline check and lube if necessary per repoe3's Dr. Splinelube thread.
unsafe at any speed
You also should be commended for your inexpensive yet stable and efficient platform.. Way to use your head...
Hope the straps are not tied to the garage door... your wife might hit the button to close the door. ![]()
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 10-03-2008 at 07:30 PM.. |
I wanna Live 'til I die!
...the things you pay attention to, Bill...
glad to see that you are in touch with the finer details of manhood... ![]()
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
I'll have another
Bill,
Yes, the nails are the latest thing. Takes going into the garage for a few hours each day for 9 days straight to get that look. It's only for the dedicated. I'm certain you've sported it out and about as well; probably much more often than I. Thanks for noticing. ![]() Yeah, I know I don't have much right to, but for some reason I'm pretty proud of my little platform...mainly for being able to make due with what I had lying around. I only had a ~50" length of 2x4 so I cut it into six 8" long pieces, screwed 'em together, and capped 'em off with particle board from a broken bookcase. Ghetto right? Not quite your custom engine stand mounted to a hydraulic lift, but it should see me through well enough. And no, the straps are not attached to the door. They are hooked through the brackets attached to the ceiling. I obviously try not to load them too much.
JY "I love twins!" ![]() Last edited by j_hurricane_y; 10-03-2008 at 07:42 PM.. |
unsafe at any speed
:d
unsafe at any speed
I have a shop manual around here somewhere, and near the front of the book, one of the hand models has a blackened thumb nail from hitting it with a hammer... Near the end of the book, the nail has let go and is missing.
I'll have another
Next time I bloody a knuckle, I'll get a shot for you.
unsafe at any speed
I'll have another
Holy crap! That's icky.
unsafe at any speed
Tuition is never cheap if you want a good education....
I'll have another
Lessons learned
I popped awake this morning dreaming of blown slave cylinders and dry spline shafts ... er, that didn't come out right.
![]() Airbox off (note I didn't find it necessary to disconnect the fuel lines from the tank, but may do so to make more room for reassembly). ![]() Here's a shot with the starter off. ![]() And here's just after the magic moment when the gear box was freed. Came off pretty easily actually; I'm sure it helps to only have 7K miles. Note I used a floor jack to support the weight of the gear box to keep things aligned as they came apart. ![]() Fortunately the interior (input side) shaft seal looks nearly new. The felt is not stained by clutch/90W goo. The felt "seal" on the clutch rod seems to have done it's job, but it is saturated and was probably only a matter of time before it let the goo past. Here's a shot. ![]() Last pic I have is of the throw out bearing in the center of the slave cylinder. You can see that the bearing race (I think that's what it is) is loose. When I get a new one, I will compare the two and post an update. ![]() BTW, the splines on the input shaft look great. There's a Honda shop nearby so I got down there this morning to pick up their Moly 60 paste which I'll apply before assembly. Back to the goo, I'm definitely going to change the "input shaft sealing ring at output end" (service manual language). Question, are the Bimmer tools the only way to go? Perhaps I'll take the entire gear box to Bob's and have 'em do it ... but I've done the rest of the job by myself so seems like wuss'n out to involve someone else now. Hmm ... maybe I can borrow a slide hammer from work .... PS. Found this thread on an alternative method to getting to the gearbox/clutch. Looks trick. http://forums.pelicanparts.com/showthread.php?t=401556
If you have goo in the trans. chamber where the slave goes then replace the slave cylinder, trans. shaft seal and the push rod felt. It does not matter weather the goo is trans. fluid, clutch fluid or water, you need to replace all the pieces. Trans. fluid ruins the slave seal and clutch fluid ruins the shaft seal. And now my pet issue with this problem. Since the clutch fluid is under pressure, when you pull the clutch lever, and the trans. fluid is not, except thermal expansion, I do not see how trans. fluid can make its way to the master cylinder. A link for seal replacement- http://forums.pelicanparts.com/showthread.php?threadid=336607 The cheap work stand with 1" bore holes in the leg ends for straps. I bought a small baking sheet that will fit between the legs and catch debris. Good luck, RB ![]() ![]() |
I'll have another
You 'da "Mann" RB.
![]() Quote:
Your stand is mo' better than mine; mine could defintely use some bigger feet for stability. Will have to swing by Ho' Depot at some point. Thanks greatly for the seal install link. That's exactly what I've been searching for and the next step in making this thread comprehensive. I love this forum.
And for all the familiar names I see who posted in the thread, ![]()
'07 R1200GS Adventure "Brutus" |
Thread Tools | |
Rate This Thread | |
