Performance Numbers
Am asking if anyone can comment. I have some stopwatch numbers, admittedly non-scientific. My question is, are these numbers typical of an S? Slower, faster, just average ho-hum?
30mph to redline in 2nd gear -- 3.38 sec.
50mph to redline in 3rd gear -- 5.54 sec.
6th gear, 80mph to 7,700rpm, 12.71 sec.
Old 01-23-2009, 02:54 PM
No try, do or not do
shreddr's Avatar
Phoenix, I'm glad you are happy with your module, but this kind of performance data seems pretty worthless, i'm not attacking you either, but you need to slap that thing on a dyno with before and after module runs, and do the partial throttle thing if thats where the benefit is. Asking somebody how fast their bike is from 30mph to redline and then showing your data to the 1/100 sec is kind of ludicrous. sorry man, find a dyno
2017 R1200GSW Rallye Shreddr Signature Model
Old 01-23-2009, 04:56 PM
roger albert's Avatar
+1 3 Significant digits is meaningless for a hand timed event.
+1 Needs dyno or means little
+1 part throttle data necessary
I wanna see Shreddr's before/after dyno numbers too
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-23-2009, 05:01 PM
shreddr's Avatar
[QUOTE=roger albert;4438496
I wanna see Shreddr's before/after dyno numbers too [/QUOTE]
i won't have before, but it turns out the guy who changed the tires on my BST's has a dyno and is some famed local tuner, (Ron from WCW, Washington Cycle Works, every hear of him Roger?) so i will have after mod data, and we can compare it to an average of stock R12 dyno runs as an indicator of what the mods did.
Old 01-23-2009, 05:08 PM
bacn5's Avatar
My 1/4 mile data:
This is some data I have on my bike. This was taken at a drag strip. If you need more info let me know.
2001 R1100SA Dakar Yellow & Black - Several Modifications
Old 01-24-2009, 07:19 AM
bacn5's Avatar
In case anyone has a data-acquisition equipment and the standard 5" wide rim with half worn 170/60-17" tire & 2.75 final drive.
30mph to redline in 2nd gear -- 3.38 sec. equals
30mph to 72mph
50mph to redline in 3rd gear -- 5.54 sec. equals
50mph to 90.7mph
80mph to 134.4mph
Old 01-24-2009, 04:15 PM
bacn5's Avatar
Phoenix,
If you can provide an accurate GPS reading in 6th gear at any specific RPM, I will provide a chart depicting your rpm vs mph in every gear. It would be best if you can provide two or three data points for example:
6th gear 3000 rpm GPS reading = 53mph
6th gear 4000rpm GPS reading = 70mph
6th gear 5000 rpm GPS reading = 88mph
Of course, I would also need to know if you have changed the final drive ratio or any of the transmission gear ratios.
This offer is open to anyone else, also.
Old 01-24-2009, 04:53 PM
rjo rjo is offline
I have some gear/speed converters, but I can't get the 1100s to work without inputting a primary reduction. The input shaft gear does look a lot smaller than the gear it drives, and my calculations need it to be about 1.9 ish, assuming a tyre circumference of 78.6".
Thoughts, or better still, knowledge?
Old 01-24-2009, 10:26 PM
bacn5: Will see if I can borrow a GPS. Nothing changed mechanically. Am running a new 180/55/ZR17 tire on the rear. As I mentioned some time ago, my access to a dyno is limited, and the two I know about in Dallas who can test bikes make no compensation for the modified air intake. Fans to cool the engine is all. Once place (140 miles one-way) I called three times took over a week to call me back, would have to leave the bike with them at least a week before they could get to it. No thanks, a long time to have something happen. Plus two long round trips smack in the heart of Dallas traffic.
Old 01-25-2009, 05:40 AM
Regnat populus
boxercup's Avatar
BMW Roundel Dyno Limitations!
Greetings,
A dyno is a measuring instrument.
Without firing air at the front of the subject bike - directly at the intake area(s) at the same speed and volume it is traveling at (NO TIME LAG) it is worthless for:
  • Tuning
  • Diagnostics
  • "Dead on Balls Accurate" analysis of the subject vehicle.
A dyno really needs a Road Replicating Dyno Cell!
Not to be confused with cooling fans, you need those also!
Here is a good calculator for your needs:
http://wahiduddin.net/calc/calc_speed_rpm.htm
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 01-25-2009, 06:41 AM
Thanks Robert, will check it out. FYI, have addressed my other issue. Based on a 9.5% increased fueling differential, I worked out a formula to determine a new base setting, which meant turning the setting down. A quick high-speed run and plug check yesterday (cold, thank goodness for my polypropelene long johns) afternoon showed the plug to be in the neighborhood of what you like. Will tweak it from there.
Old 01-25-2009, 07:25 AM
Regnat populus
boxercup's Avatar
Thumbs up Nice Work!
Greetings phoenix,
Good, nice work!
Remember<> Be safe... and Have Fun!!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 01-25-2009, 07:38 AM
