1200S battery replacement ???
Anybody know which Odyssey slips into the R1200S ????
Old 12-26-2009, 12:24 PM
Uh....who me?
Bob Hancock's Avatar
I replaced mine with a maintenance free Yuasa that has been working fine. However, I lost the receipt. The local Honda shop had it in stock though and cross-referenced it through their system....a fairly common battery and about half the cost of a new bonafide BMW battery.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 12-26-2009, 12:41 PM
fralind's Avatar
Pc545
Old 12-26-2009, 01:02 PM
Wait a minute, elsewhere people say PC 535 . Which one is correct ?
Old 12-26-2009, 06:30 PM
peter f's Avatar
Frank
Type is PC535 NOT 545. Fits perfectly.
I ordered mine from Motorworks (UK). Funny thing is that they replied by asking to explicitly confirm my order - see below...
Sorry we are not sure if PC535 will fit the R1200S, are you sure you want to try? We cannot refund the postage if it does not fit, I will leave the order on hold until you get back to us.
Best wishes
Motorworks
R12S, black, ex Ohlins (now WP), full HPE, RB3
Old 12-26-2009, 10:19 PM
fralind's Avatar
Hawker Odyssey PC 545
12,0 V, 14Ah 545A
L: 175,0 mm, B: 83,0 mm, H: 130,0 mm,
Gewicht: 4900,0 g,
M6-Anschluß / Gehäuse rot oder schwarz
12.0V, 14Ah 545A
L: 175.0 mm, W: 83.0 mm, H: 130.0 mm
Weight: 4900.0 g
M6 junction, red or black casing
Hawker Odyssey PC 535
12,0 V, 15AH 535A
L: 170,0 mm, B: 99,0 mm, H: 156,0 mm,
Gewicht: 5200,0 g,
12.0V, 15Ah 535A
L: 170.0 mm, W: 99.0 mm, H: 156.0 mm
Weight: 5200.0 g
Old 12-27-2009, 02:04 AM
peter f's Avatar
Frank
Yes I know the dimension differences...but since the PC535 fits perfectly into that tray...(And I haven't modified it, he he). Besides M-TEC/Wunderlich offer type 535 as well.
It's like the Godzilla thing > bigger is better (size does matter)
he he
Old 12-27-2009, 02:36 AM
fralind's Avatar
ok
Old 12-27-2009, 04:22 AM
Okay, are you guys saying that BOTH the 545 and the 535 will fit ? Isnt the 545 just a wee bit hotter cranking power ?
If the 535 will fit, why not the PC 625 ? The 625 is the same dimensions as the 535 except just a wee-bit taller , by about 3/4 inch. The 625 is even hotter than the 545.
Old 12-27-2009, 04:30 AM
peter f's Avatar
Well...true (but count some free play required to put the thing in place) but in my case the free space is full with some weird relay (operates a custom SPAL oil cooler fan) AND that **** RapidSomething thing.
In any case go to a shop and try the 625 (bigger always is better, he he).
Old 12-27-2009, 04:39 AM
Yeah, I gotta go out and look at mine. Maybe that increased height of the PC 625 would be okay.
Old 12-27-2009, 05:01 AM
The correct battery is a PC 535,the 545 is what goes in the 1100s that comes without heated grips,PC 680 with heated grips,although you can run the bike on either,a completely separate thread!!.
Old 12-27-2009, 05:30 AM
fralind's Avatar
When the PC 535, the poles are reversed.
The German wiring harness is in the series to end up too short on the pole
Bei der PC 535 sind die Pole vertauscht.
Der deutsche Kabelbaum ist in der Serie dafür zu kurz an den Pol enden
Old 12-27-2009, 06:24 AM
Uh....who me?
Found the receipt. I replaced mine with a Yuasa PUYTX14-BS. Description says "Battery-maintenance free.69 Liter". Cost was $95.95.
FWIW. Now back to our regularly scheduled technical battery discussion.
Bob Hancock
Old 12-27-2009, 06:36 AM
AZ-J's Avatar
Send a message via AIM to AZ-J
Thanks for this. But now, I am more confused on this subject than when I started reading this thread.
Does the US wiring harness reach for the reversed poles of the PC535?
I may need a battery soon for my R1200S. I want an Odyssey battery and I need to know which one is correct.
I also know a local Batteries Plus has the PC535 because weeks ago I called for one, but my battery is still good (enough). I did not ask if they had or can get a PC545, but I'd bet they could.
Thanks for any enlightenment anyone can provide regarding the US model R1200S.
’68 R50/2(1968 was Dad's then mine to 1990) SOLD
’07 BMW F800S (3/2007-9/2008) LEMON'D
'07 BMW R1200S black CF/white tank panels (acquired 10/24/2008)
My bike here:
http://tiny.cc/MyBike
Old 12-27-2009, 10:07 AM
Yes, and Im curious still about the PC625.
I would think the US wiring harness is the same as the German but maybe not. Attaching an extension would be no problem.
The question is whether the increased height of the 625 would be a problem. Lol, I need to go pull my seat and take a look.
Old 12-27-2009, 11:22 AM
AZ-J's Avatar
I don't think mine could take the height increase of the 625. The Code Check module is mounted there, right above the battery.
My bike here:
Old 12-27-2009, 11:50 AM
Droptarotter's Avatar
I thought is was the PC 535 for US models as the positive terminal is located to the right front.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 12-27-2009, 02:03 PM
No try, do or not do
shreddr's Avatar
Originally Posted by droptarotter View Post
i thought is was the pc 535 for us models as the positive terminal is located to the right front.
Cheers
+1
2017 R1200GSW Rallye Shreddr Signature Model
Old 12-27-2009, 02:45 PM
AZ-J's Avatar
Thanks. I guess I was just "turned around".
My bike here:
Old 12-27-2009, 03:30 PM
