lht lht is offline
What did you use to install the new glass or plastic one?
LT
Old 01-26-2014, 02:44 PM
diz plaz is cwazy
RIQUE's Avatar
Getting it out was harder than I expected. The oil seal rubber was firmly seated to the engine metal and would not budge. You need a proper oil seal removal tool. The one that looks like a two headed axe. Installing is also a bit tricky as the new glass window is more fragile. I used a standard socket the same size as the out diameter of the seal and carefully pushed it into its seating position. The darn seal kept popping out at first. After seating well I gave the socket a good whack with a hammer and quickly put in the fastening clip. As recommended by the manual I put a thin layer of RTV around the seal. Started her up to check for oil leaks and thats it.
Life rewards action, He who is not afraid is safe!
A Zest for living requires a willingness to die!
BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny
BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo)
Old 01-26-2014, 03:24 PM
