Phil Y's Avatar
Discount Starter
Anyone try THIS? At this price, would be cheaper than repairing the old one. All the reviews are good.
Phil Y, Kapolei, HI
04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar
"There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago
Old 05-18-2017, 07:55 PM
Registered Agitator
sgoodwin's Avatar
There were some posts here awhile back about these new cheap starters. Claims of plastic gears were presented that would break or wear prematurely rendering them useless far earlier than better more expensive units. I personally went for the OEM Valeo starter at 3 times that cost just for peace of mind as the original had last 2 decades plus, but was so destroyed it was a toss up for rebuild vs replacement. I choose to replace as everything would be new not just the replacement parts.
Old 05-19-2017, 04:32 AM
Phil Y's Avatar
OK, rather than going with a cheap Chinese knockoff, I got a brand new Valeo from EME for "only" $189. Go HERE if you're interested.
Phil Y, Kapolei, HI
Old 05-22-2017, 08:03 PM
Hey Phil, I installed that exact same discount starter a month or two ago and has done its job thus far. Given the oem starter's magnets had completely dissentigrated, I wasn't real eager to buy another at three times the cost. If I get a couple years out of it, I'll be happy as replacement is easy and straight forward.
'99 R11s | '91 K75 | '75 R90/6
Old 05-23-2017, 08:07 AM
buzzerbee's Avatar
I would go this route. I have been well satisfied with the products and the service/ship time is superb.
Old 05-23-2017, 09:06 AM
Phil Y's Avatar
bimmerphan: Did you have to remove the Tupperware to do the replacement?
buzzerbee: Agreed. Priority mail was cheapest: ordered on Fri, received on Mon . . . to Hawaii, no less!
Phil Y, Kapolei, HI
Old 05-23-2017, 11:43 AM
Send a message via AIM to tomvv11
On my original Valeo starter I just discovered that end of the plastic collar around the reduction gears overheated and melted away, allowing the metal grease cover to grind against the end of the motor windings. The magnets were covered in grease and had a shard or two of the cover stuck to them. No wonder it cranked kind of slowly even with 12.5+V at the battery. Trying to fabricate a metal grease cover to fit into the somewhat now shorter plastic collar.
Old 09-23-2017, 09:05 PM
I installed a Nippondenso starter ( around $350 ) a few years ago and haven't had any problems.
If installing on a R1100S , the starter cover has to be modified.
Motorrad Elektrik Replacement Starters Airheads 1977-1995 Call now! 256-442-8886
2004 R1100S
Old 09-24-2017, 10:25 AM
Scroo that. Discovered that Euro Moto Electric sells both of the damaged parts I need for about $25 total. Magnets are fine, spiral throwout gear a little bit knurled but OK, a few bits of plastic broke off the brush holders when I disassemble but brushes seem to hold. Just have to get that C clip back on gear shaft when I reassemble. Already not looking forward to that, judging from other posts.
Old 09-25-2017, 12:54 PM
