Speedometer needle remove
How do you remove speedometer needle without any damage to the mechanism in Porsche 981 ?
Wysane z mojego SM-G955F przy uyciu Tapatalka
Old 02-08-2019, 10:13 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - this is generally not something we suggest as a DIY unless you have a lot of previous experience working with speedometer/odometer replacements. From my understanding, most people use North Hollywood Speedometer for repairs. Other members will likely chime in with their expertise as well.
Old 02-08-2019, 11:10 AM
I'm going to change speedometer disc for the km/h. I just want to know how you remove the needle. Pulling in 0 position? or there is special technique ?
Old 02-08-2019, 11:38 AM
Your digital speedometer will still be in mph, as will your trip meter and odometer will still be in miles. And there's a chance you will fubar the needle or needle drive. 0 position is where you should start at, gently try to pull the needle off. After you're done, check the accuracy with gps, you can adjust it by pulling the needle back off and repositioning it.
Be gentle!
I suspect you're in Europe. If all else fails, you can probably find a used cluster on Ebay.
Note, I've never done this on a Porsche, but have done it on American cars to adjust the accuracy of the speedometer.
Brian Lamberts
Tucson AZ
Old 02-09-2019, 08:07 AM
Thank you for your reply.
I changed digital options in menu. Now I want to change the gauge face to km/h.
I have plastic tools and new gauge face to do it but I still collect tips&tricks.
I worry about the gauge needle... how to remove and attach...
I found tutorial in the internet but I want to confirm if it works in Porsche.
https://revlimiter.net/mods/gauge_install.php#needles
Yes, I am in Europe
Old 02-10-2019, 05:17 AM
Try using a plastic fork to slide under the needle & pull straight up.
Old 02-12-2019, 03:07 PM
Occasional User
Cook&Dunning's Avatar
I think these guys make most of the replacement dials for Porsche - how about asking them for advice / instructions?
FVD Brombacher https://www.fvd.net/de-en#
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 02-13-2019, 08:07 AM
Done
It was not so difficult.
The most challenging was disconnection of the instrument cluster because there is special locking mechanism.
And I had to repositioned the gauge needle because of slight different in the speed measurement about 2-3km/h.
The gauge needle jumped without any problems even second time.
Thank you for your tips&tricks.
Old 02-13-2019, 01:55 PM
