odometer light out 986 / 2000
m My odometer light went out two days ago. Checked all fuses and there good Any one have any ideas?
Yes, the bulb is burnt out; time for a replacement.
Accrochez-vous bien de vos rêves..........." |
The Odometer digital display on my 2002 Boxster S shows the bottom half of the miles driven number (less the last digit) and the top half of the Trip Odometer numbers. In addition, upon startup, the oil level display does not show. Is this caused by a burnt out LED bulb? I have no OBDII fault codes showing. Any ideas, Thank you
Administrator
https://www.pelicanparts.com/techarticles/Boxster_Tech/102-ELEC-Instrument_Cluster_Bulb_Replacement/102-ELEC-Instrument_Cluster_Bulb_Replacement.htm |
Administrator
2002 Boxster S Odometer Lignt Half Gone
First try at uploading image. If this did not work will try again
