986 Boxster S instrument cluster not working
I have got a problem with 986 Boxster S instrument cluster not working properly;
- the analog speedo and rev counter do not move, both gauges do not move at all - mileage, etc. on the lcd screen at the bottom of speedo do not illuminate All other instruments function normally; fuel gauge, indicators, etc. all ok. I connected with Durametric, and I checked the following - engine rpm shows (i.e., rpm signal comes from engine dme) - in the activations menu, I can activate; rpm --->8000 ok speedometer ---> full speed ok However, I cannot activate lcd screen all pixels, the lcd part stays entirely dark, nothing shows. Please any ideas where to start diagnostics? Cheers!
1996 993 Carrera 1998 996 Carrera 2000 986 Boxster S |
I have a little experience with the clusters based on swapping a Carrera cluster into my car. I prepared a document with some notes and pictures. If you send me a PM with your e-mail address, I'll forward it to you.
I don't have any experience with the problem you are experiencing. Have you removed the cluster for any reason such as to replace a light bulb? If you removed it, perhaps you did not seat one of the connectors correctly when you reinstalled it. If this sounds like a possibility, I suggest you remove and reinstall it. Wayne has published some good instructions here: Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) - If it was just one lcd not illuminating, I would suspect a failed bulb, but it seems like a big coincidence that all of them would burn out at the same time. Perhaps there is a fuse that powers part of the cluster that is out. I think you need to check B1, B10 (both 15 amp), and E1 (7.5 amp). However, since you have a car built for Sweden your fuse layout may be different. So check the chart under your fuse cover. Another remote possibility is a fault with your ignition switch. Good luck with trouble shooting. Last edited by KevinH1990; 06-18-2013 at 03:34 PM.. |
Was this problem ever resolved? I have almost exactly the same problem at the moment with my 986.
Mr rev counter is completely erratic and has a mind of its own. I have been told the coil packs breaking down could cause this, any hep would be appreciated. Dean
Sorry I should have said its a 2000 996 Boxster 2.7 And the car runs fine no issues and the OBD has no faults found...
