Take it easy on me - Need Immobilizer/restoration advise
A little background first: 1999 Boxster (986) Base. Replaced top with a glass top. Glass broke somehow while driving. Filed insurance claim. Insurance has been a PITA to deal with so I parked the car.
Car got wet, so I'm sure you know where this goes. I have a new/used immobilizer from eBay on its way. I've been reading as much as I can... and it seems there's some programming that needs to be done. Is it economical to just replace the immobilizer and have it towed to the dealer to reprogram? The keys I have are apparently original but neither of the remotes has ever worked (one didn't have the transmitter, the other one has a bad switch). I'm also considering pulling a full set (immobilizer, ECU, Ignition Key switch, immobilizer, door lock)from a local parts car. I do have some concerns. First, what's the most cost effective way to approach this? Second, would I lose the "low mileage" from my car when I replace the ECU from another car? Third, Is there a "consumer" tool that can allow me to reprogram the keys and ECU so I don't have to take the car to the dealer? Thank you for your recommendations. |
I would 1st call "ECU Doctor" too talk to them, much better if they can restore your original. Put rice in your original "wet" ECU to absorb water & dry it out.
Thanks for the reply. I'm a little confused. There seem to be two ECU doctors. one in FLA and one in CA. But I still don't know if I have to take the keys, the ignition switch ECU and immobiliser to ship to them...
I have a whole video on how it works using ECU Doctors in Florida. Easy to work with and fast turn around time.
https://youtu.be/BOB2cL2J6XU Brian
Thank you Brian,
That video has been most straight-forward and informative. I just hope I don't have to sink $1000 into it. ![]() Thanks again! |
| Tags |
| 986 , boxster , immobilizer |
