Replacing Seat Switch
I am replacing the drivers side seat switch. How do I lift the cushion to get to the connector? I see the two plastic clips. I have popped the retaining pins, but what is next to pull the retaining clips from the cushion to the seat frame?
Once you have the round pins pulled free of the plugs, you need to prise them out of the plastic seat base. They are spade-shaped and can be pulled free by twisting a screwdriver blade between the seat base and the plug. They rotate forward and then the seat lifts up at the front and slides out from the back.
