-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   '97 Boxster O2 connector access..? (http://forums.pelicanparts.com/showthread.php?t=1128363)
LloydJohn 10-18-2022 09:32 PM
Greetings,
How do I access the rear (Cat) O2 wiring connector? Ive read posts and watched Youtube etc. vids but nowhere do I see info on what to do with the wire that runs up and behind the aluminum heat shield. I see a small 8mm nut in that area and am hoping removing that will give access to the connector. Is it that simple or do I have to remove more or do something different?
LLOYD
mikefocke 10-21-2022 02:24 PM
https://sites.google.com/site/mikefocke2/oxygensensors see the picture with the screwdriver inserted.
If you are removing the sensor from the exhaust, then see the picture of a special wrench.
Any muffler shop can handle the removal, no need for P-car prices.
Starter986 10-31-2022 04:42 AM
Originally Posted by Fernando56 (Post 11834869)
We have been using this for a colossal piece of a time now and it is clearly going charmingly.Thankful for the little by little useful exercise. Has conclusively the ordinary impact!I figure you should check out the sitename support site. MyFlorida Access Login Account
What. The. ****. ?
