“screech”
1999 Boxster base …when starting’(especially when cold) I get a momentary “screeching noise. It only lasts fora second. It’s been doing this since I purchased it 4 years ago. Any thoughts based on experience?
Old 06-26-2023, 12:16 AM
Idler on the serpentine belt???
Tony G
2000 Boxster S
Old 06-26-2023, 12:20 PM
It can be serpentine belt or pulley related. Replace the belt if you haven't already done so and before putting on the new belt, make sure to spin every pulley that you can to check for any resistance or noises.
Old 06-29-2023, 01:21 PM
Going faster all the time
Litesonic's Avatar
I learned a while ago that a screech is usually a loose belt asking to be tightened.
Easy enough to inspect on a boxster, and you will feel oh so mechanically inclined.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 07-22-2023, 03:17 PM
maxnine11's Avatar
My Boxster had a starter with probably a gummed up solenoid/starter drive that would make a screeching sound on start up sometimes, especially when cold. Basically, it doesn't disengage from the ring gear quick enough when the engine fires, so spins for a split second at a zillion rpm.
Probably could have cleaned up the old starter, but decided to just put a new one in while everything was apart.
max
Old 07-23-2023, 08:56 AM
srg srg is offline
Air - Oil Seperators can make some wild noises too
Old 07-28-2023, 10:45 AM
