Clear Flood Mode
Can anyone tell me if a 2007 base Cayman has a clear flood mode? Thanks in advance.
Old 07-08-2025, 08:03 AM
JFP in PA's Avatar
No..............
Accrochez-vous bien de vos rêves..........."
Old 07-08-2025, 09:01 AM
Thank you for your reply.
If the car has not been started in over a year, would it be advisable to pull the fuel pump relay and then crank it to circulate some oil? Any other best practices?
Also, do you know if the battery must be programmed?
Thanks again.
Old 07-08-2025, 02:02 PM
JFP in PA's Avatar
Cranking the engine into oil pressure is always a good idea on one that has been sitting.
Battery should not be an issue.
Old 07-08-2025, 02:58 PM
Thanks again.
Old 07-08-2025, 05:59 PM
