Bought Durametric
'14 Boxster S
I ran the durametric for the first time and did a short test on all modules and it shows almost everything as fault codes. Mostly communication problems. I did the test with the engine running. Car runs fine only alerts on the dash are "oil over fill", "service due" soon and sometimes the "start stop function" not working.
Should delete and error codes and run the test again?
Here's partial copy and paste of the results
Short Test
PASM with PADM
Current Fault Codes
c12019:
No communication with air conditioner regulator
Warning Indicator Off
Test Completed This Monitoring Cycle
Test Not Failed Since Last Clear
Test Completed Since Last Clear
Not Pending DTC
Test Not Failed This Operation Cycle
Fault Passive
Engine Module Siemens EMS SDI 9
Current Fault Codes
C1500:
Upper limit value exceeded
C2400:
No signal/communication
C1900:
P2400:
Value below lower limit value
C2400:
P2800:
Dual Clutch / Doppelkupplung - PDK
No Faults Found
Porsche Stability Management / Anti-lock Brake System (ABS)
Current Fault Codes
c12019:
Not Pending DTC
Fault Passive
c12096:
Check instrument cluster fault memory content
Not Pending DTC
Fault Passive
c12196:
Not Pending DTC
Fault Passive
c12018:
Not Pending DTC
Fault Passive
Electronic Parking Brake
Current Fault Codes
c12018:
CAN timeout error, instrument cluster
Not Pending DTC
Fault Passive
c12096:
Not Pending DTC
Fault Passive
40:
Warning Indicator On
Not Pending DTC
Fault Passive
Tire Pressure Monitor
Current Fault Codes
c12016:
No communication with front-end electronics control unit
Not Pending DTC
Fault Passive
c12096:
Not Pending DTC
Fault Passive
Heating and Air Conditioning - HVAC
Current Fault Codes
10:
Not Pending DTC
Fault Passive
1194:
Not Pending DTC
Fault Passive
1304:
Not Pending DTC
Fault Passive
1314:
Not Pending DTC
Fault Passive
c12000:
Not Pending DTC
Fault Passive
c12007:
Not Pending DTC
Fault Passive
c1201d:
Not Pending DTC
Fault Passive
c1201f:
Not Pending DTC
Fault Passive
Old 08-31-2025, 04:33 PM
This is a legit Durametric and not a clone? Has the car ever passed diagnostic tests?
Old 08-31-2025, 04:54 PM
I bought the tool from Durametric.
The car is a Carvana purchase.
Car was serviced at Pittsburgh Porsche for the last 6 years last seen 1 year ago, before that it was serviced at a Porsche dealer in Fairfield Ct.
According to carfax.
Old 08-31-2025, 06:23 PM
I would clear them all and check again after several days of operation.
Old 09-01-2025, 05:17 AM
Clear the codes and see what comes back after several drives.
Sent from my SM-S938U using Tapatalk
Old 09-01-2025, 05:39 AM
I don't know if this makes any difference. The air conditioning controls were sticky from spilt coffee or mocha, had to remove the PCM and air controls to clean it. All went back together and works fine.
Old 09-01-2025, 08:02 AM
I cleared the codes and will recheck after driving a bit.
Plugged it into the '14 Cayman and it showed a few faults, one of the head lights, e brake, radio maybe 1 or 2 more, I see no problem with any of that so I just cleared them.
I'm operating the software with the engine running to keep from weakening the battery. When using some commands like tool information and resetting the service reminder the computer can run very slow and freeze. The service reminder would not reset with 2 tries, I ran these commands with the ignition on engine off and they responded fast and no freezing.
If using the software with the engine off should a battery charger be used? I've seen that recommendation for a VW cable from ross-tech.
Old 09-03-2025, 12:22 PM
You should always use it with the ignition on, engine off. If you are going to be using it for a bit, yes, I'd hook up a battery charger to it. If its just to reset the maintenance, I likely would not.
Old 09-03-2025, 01:36 PM
