-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Replace climate control unit (http://forums.pelicanparts.com/showthread.php?t=325933)
chilli 01-20-2007 03:46 PM
For my 2002 S with the climate control at bottom of console, wondering how difficult to replace the unit. Have not even looked at the mounting of the unit. Anyone know of any procedure available. Did some searching but could not find anything.
mikehttp://forums.pelicanparts.com/uploa...1169336790.jpg
BT911 01-23-2007 07:28 AM
just pull the small black plastic trim out with a small pick and there are 4 screws. and then you got to get it coded at a dealership.
JMatta 01-23-2007 02:01 PM
As BT911 said, it pulls out quite easily after removing the trim and mounting screws. I moved mine to the top of the center console, replacing the cupholders. Is your unit not working, hence the question? I was not not aware they had to be coded to specific cars.
chilli 01-23-2007 02:21 PM
It is working but the lcd is starting to creep inwards from the right side. Have a replacement that I want to just swap in.
mike
BT911 01-23-2007 08:29 PM
you have to code it to allow the values of the flaps to get set and caliberated
