Won't Continuously turn over
As if my Boxster doesn't already have enough problems it seems there's a new one. The latest thing its doing is not continuously turning over when being started.
When you turn the key it turns over 1 or 2 or sometimes 3 times then stops turning over. If you turn the key off it does the same thing again. It won't continuously turn over though. I tested the starter and solenoid and they are fine. Is this a common issue? I know the ignitions are crap in these cars, does this sometimes happen when they go? Is there a relay that could be causing this? |
You have load tested the battery I'm sure.
I tested the battery and it tested fine. Then I pulled the battery from my Daily Driver and the Porsche still did the same thing with that battery.
Was a bad ground on the engine. Cleaned it up and car turns over. All fixed
Author of "101 Projects"
Cool deal. I mention this in the battery section or the starter section of the new Boxster book!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
