-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Massive Engine Problems... (http://forums.pelicanparts.com/showthread.php?t=603734)
scotty (guest) 04-18-2011 10:59 PM
i have 99 boxster the engine locked up after driving . I hear something snap when i tryed to start it . I rolled car back and forth then it started but sounded like hell. I turned it off. sence then i changed intermediate shaft bearing and still sounds bad. Now have taken engine out and timeing chain on drivers side is loose . what to do and what is best manuel for job?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Porsche Boxster / 996 Engine Teardown & Disassembly
Wayne 962 04-18-2011 10:59 PM
Yikes, that sounds like a challenge! I'm going to copy your question to our forums, and then we can help you there with some suggestions.
- Wayne
Cajundaddy 04-19-2011 07:03 AM
Start by draining the oil through a screen and then drop the pan to see how bad the carnage is. If it looks like a grenade went off there is probably nothing left to save at this point. It already sounds like pistons and valves were making contact so not good news. Time for a 3.4L??
BYprodriver 04-19-2011 10:48 AM
Get the Porsche manual set, try Sunset or Suncoast Porsche.
JFP in PA 04-19-2011 01:45 PM
Also be prepared to buy/borrow/steal/rent some tools you thought you would never have need of.........
