Guest
Posts: n/a
i have 99 boxster the engine locked up after driving . I hear something snap when i tryed to start it . I rolled car back and forth then it started but sounded like hell. I turned it off. sence then i changed intermediate shaft bearing and still sounds bad. Now have taken engine out and timeing chain on drivers side is loose . what to do and what is best manuel for job?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Porsche Boxster / 996 Engine Teardown & Disassembly |
Author of "101 Projects"
Yikes, that sounds like a challenge! I'm going to copy your question to our forums, and then we can help you there with some suggestions.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Start by draining the oil through a screen and then drop the pan to see how bad the carnage is. If it looks like a grenade went off there is probably nothing left to save at this point. It already sounds like pistons and valves were making contact so not good news. Time for a 3.4L??
2021 Cayman GTS 4.0L 2020 Macan (dog hauler) |
Get the Porsche manual set, try Sunset or Suncoast Porsche.
Also be prepared to buy/borrow/steal/rent some tools you thought you would never have need of.........
Accrochez-vous bien de vos r๊ves..........." |
