Scott O (guest)
Guest
Posts: n/a
This is a great forum.
My 2001 Boxster S top suddenly stopped working. It is in the up / closed position. When I release the top windshield lever, the windows lower an inch like normal, but when I press the dash mounted switch, nothing happens. I think this may be a switch but I don't know how to diagnose this.
Please offer a suggestion. Thanks,
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987
Old 09-30-2011, 11:29 PM
Author of "101 Projects"
Wayne 962's Avatar
There are a few switches that could be causing this issue. There's one in the back by the motor. There's one in the top of the windshield, and then there's one on the e-brake. I would probably check out all three of these first before moving onto the next step.
- Wayne
Is the parking brake dash light ON when you pull the brake lever, if not, then the parking brake microswitch could be the culprit! just happened to me 6-7weeks ago.
Good luck! keep us posted...
Old 10-01-2011, 08:47 AM
If it does end up being the parking brake switch, you can take the no cost route and ground it at the relay so you avoid the need to have the parking brake engaged.
Vince
Old 10-01-2011, 10:56 AM
bar10dah's Avatar
How do you ground it at the relay? What pin to what pin? In Bentley, EWD-89, appears parking brake is marked A5, BN/YE. Just attach that to any ground?
Old 04-30-2012, 08:30 PM
Try this: Top Operational while-in-motion
Old 05-01-2012, 07:48 AM
bar10dah's Avatar
Nope, that doesn't help. But thanks Boulderick.
Old 05-01-2012, 03:11 PM
