Doug&Julie's Avatar
Major Service - Before or After Winter?
I'm at 39k miles and due for a major service on my 2006 Cayman S. But it's mid-November and I'm very close to putting it away for the winter. To be fair, I'm going over-inflate the tires and put a trickle charger on it. That's it. I'll probably get it out on decent days throughout the winter for drives long enough to truly warm up the car. But that might be once or twice a month. So my question is would it be better to hold off on the 40k service until Spring? ..or should I do it before Winter anyway? I know it's recommended to change the oil before "storage", so I'm leaning toward the later. But my wallet would prefer the former.
Any thoughts would be appreciated.
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 11-16-2011, 07:44 AM
Doug&Julie's Avatar
OK, I've just booked the service for "before", but I'd still like to hear your thoughts.
Doug
Old 11-16-2011, 08:15 AM
Cajundaddy's Avatar
Most suggest changing your oil before winter storage. Water and fuel contamination in your old oil is the enemy. If moisture collects at the bottom of the case over winter it may begin to corrode the IMS bearing causing early failure. Take your car for a spirited drive and get the oil nice and hot. Then have your oil changed and put her away with a clean crankcase.
2021 Cayman GTS 4.0L
2020 Macan (dog hauler)
Old 11-16-2011, 08:19 AM
JFP in PA's Avatar
Before.
Accrochez-vous bien de vos rêves..........."
Old 11-16-2011, 11:31 AM
Doug&Julie's Avatar
Thanks guys. Cajundaddy your explanation makes perfect sense. Schedule appt for Nov 28th.
Doug
Old 11-17-2011, 05:08 AM
