Blaze (guest)
Guest
Posts: n/a
I have a 2000 boxster s with 45k miles and just had the clutch replaced about 3 weeks ago. Now the shift lever will only operate R, 1st & 2nd. I'm being told in needs a new clutch cable assembly. Can this be a result of damage during the clutch replacement or improper installation?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Parts - Error: Page Not Found
Old 12-18-2011, 01:02 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, the Boxster doesn't have a clutch cable, so whomever told you that really has no idea what they are talking about. To me, it sounds like indeed, there is something wrong with the release of the clutch - maybe the clutch hydraulics need to be rebled. If the clutch is not disengaging, and you keep driving the car in this condition, then you will put a lot of wear on your transmission.
- Wayne
harryrcb's Avatar
sounds like the shift cable was not installed properly and yes the cables had to be removed to replace your clutch. the 2 cables outer sleeve needs to be locked in a bracket or it will not shift properly.
Crazy Austrian
http://www.ws-ab.com
Old 12-18-2011, 08:32 PM
