Remove the carbon canister
On a 2008 boxster there are two plugin coupling going to the carbon canister. There is only about one inch of space to access these coupling. How do you release these coupling from the canister?
Old 02-14-2012, 08:57 AM
bar10dah's Avatar
I think when I did it, I pulled the cannister out. Should be one 10 mm nut on the inner side of the cannister. After that nut is off, you'll have to get your hands on the top and bottom, rock the cannister back and fourth, up and down, and it'll pull free from the two rubber grommets on the back. It's very tough to pull out as the rubber grommets hold onto the two tabs very tightly.
Old 02-15-2012, 09:30 AM
Tags
boxster , carbon canister , coupling
