i can not push clutch pedal to the very end
Hello,
i met problem. I was waiting for green light and suddenly realize that my clutch pedal can not be pushed to the very end. So i was not able turn on 1st speed and move. So know I can not even start engine for the same reason. There was no any mechanical hit before problem. The last time pedal perfectly worked - 30 seconds before problem.
Does anybody met such problem.
I can push pedal for 60-70% and than feel hard stop of pedal movement.
Thank you
Old 06-12-2012, 12:35 PM
Hi. I often have the same problem. The solution I have found is to remove the empty beer can than has rolled underneath the pedal. Once gone the pedal works fine.
Old 06-12-2012, 03:05 PM
bar10dah's Avatar
First thing I'd do is check all the linkages and connections to make sure nothing has worked itself loose.
Old 06-12-2012, 04:36 PM
