exhaust camshaft cover
just trying to ensure I've got the right camshaft cover - doing the IMS bearing retrofit, and need to pull the camshaft exhaust plugs off to be able to mark the position.
Does this look like the cam plug?
Another photo
Author of "101 Projects"
That's the chain tensioner. You really need to read my article *very carefully* before you attempt this repair. I don't intend to sound mean, but if you can't identify the cam plugs, then you are probably not prepared to do this quite yet. Here is the link to the article, read it carefully, then read through it again, and post back here if you have any additional questions. Here's the link:
Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06) -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Oh, and for reference, the cam plug cover (intake):
![]() -Wayne
Hi Wayne,
Thanks for the note; this comment in your article has me scouring the bottom of the engine for the exhaust camshaft covers -"The exhaust camshafts are located on the bottom of the engine." Don't the camshafts run parallel to the crankshaft? Wouldn't the camshaft ends be on either the front or rear (flywheel) end of the engine? |
The exhaust camshafts are on the bottom of the engine. The intake cams are on the top of the engine. However they both run front to rear parallel to the crank. I think he's just trying to differentiate between the two camshafts with the comment you quote.
Jeff |
Hi Jeff,
Thanks for the info. I think it's semantics: when you say 'bottom', I'm looking at the underside of the engine. If you said 'lower half or bottom half' of the flywheel end, that's where I'd look. I'm just following the instruction precisely, and this one has me confused, because it's not clear to me. Thanks, Phil |
camshaft covers
attached is a picture of the left side (of the flywheel) cam covers showing 2 cam covers. Upper must be the intake, lower the exhaust.
camcover
this is on the right of the flywheel - one cam cover that I can see. Since this is upper, is it an intake?
