Unable to open roof
I am unable to open my hood on 1998 Boxster, fuses have been checked but hood still won't open. Can anybody help ???
Roof? Hood? If the top, your e-brake switch may have failed.
roof failure
Emergency brake micro-switch that signals the top motors via a relay that the car is stopped and the brake applied and it is OK to open or close the top. So jiggle the e-brake handle. Possible to bypass via a relay pin bending hack. Or better yet, buy a specialized relay that always assumes you know what you are doing and doesn't require the e-brake to be engaged.
Hood is the term for Top over on the other side of the pond. It always helps to know where you are and the model year so we can help you better. |
Thank you I will try this and post again
I had the same issue once. I was told to move the emergency brake handle up and down vigorously for a little bit and it worked great!
Thanks I have tried that but still having no success.
Is the ebrake light on the dash going out when you release the ebrake? Is it on at all?
| All times are GMT -8. The time now is 11:46 PM. |
