Socket for Chain Tensioners
If you are in need of the 32 mm socket to fit the Chain Tensioners, I suggest you check out the Lisle 14700. It is intended for the oil filter for the GM EcoTech 2.2 liter engine.
I has a very low profile and is 3/8 inch drive. This makes it perfect for reaching the front Tensioner on the Boxster engine with a swivel and a 6 inch extension. I bagged one at my local O'Reilly's for 9 bucks.
Gas Junkie
2001 Base Boxster
Old 11-06-2012, 06:36 AM
