2006 cayman S issues?
do the caymans have the same IMS and RMS issues as the boxsters? looking at a 2006 cayman S with 100,000 miles on it....any other thoughts appreciated
Old 12-14-2012, 05:48 PM
JFP in PA's Avatar
Yes, they use the same engine. You should also be aware that any Boxster or Cayman built after 2005 and up to 2009-10 have the "final solution" IMS bearing in them that cannot be upgraded without a total engine rebuild..........
Accrochez-vous bien de vos rêves..........."
Old 12-14-2012, 07:01 PM
CrownCityBoy's Avatar
Just to be clear, model years 2006-2008 are the "final solution" years. Model years 2009+ are Gen. II.
Old 12-17-2012, 08:13 PM
2001 Boxter S
What JFP means, in models from 05 (some of them) 06,07,08.
The bearing is the final solution. In other words, cannot be replaced.
These models are still considered as candidates for IMS failure.
Models from 09-10 and up, do not have the IMS at all, so this problem is solved with these models.
Old 12-17-2012, 09:39 PM
JFP in PA's Avatar
2009 was a transitional year for the base 2.9L engine, it had no IMS as it was a 9A1 design, but it also lacked DFI (all 2009 "S" engines are DFI). In 2010, the 2.9L rather abruptly disappeared to be replaced with a 2.7L 9A1, with DFI. A lot of people think the 2.9L engine was a better performer, even without DFI.
You also have your "generations" wrong, the M97 engine was "Gen II" for the M96/97, the 2009 2.9L 9A1 was "Gen I", the 2010 2.7L version was "Gen II" for the base 9A1 engine.
Old 12-18-2012, 04:47 AM
I believe the 2.9 engine was the base engine for Gen ll cars through 2012. I have a 2012 base Cayman with a 2.9 engine.
Old 12-18-2012, 07:14 AM
JFP in PA's Avatar
The non DFI 2.9L engine became the base for the 2009 Cayman, but not the Boxster after 2009, that uses the DFI 2.7L:
Technical Specs - The new Boxster - All Boxster Models - Dr. Ing. h.c. F. Porsche AG
The 2012 Cayman also went "retrograde" to the 2.7L engine as well (page three of the engine section):
"2.7-liter engine
The Cayman is equipped with a free-revving 2.7-liter flat-six engine with Direct Fuel Injection (DFI) and VarioCam Plus. It develops 275 hp at 7,400 rpm. The maximum torque of 213 lb-ft. is available across a wide speed range from 4,500 to 6,500 rpm. "
http://m.porsche.com/;s=FJJ3UnEFcHD19MKEm_dsc21/usa/models/cayman/cayman/detail/
Yes, I know what other trade press have stated, but this is direct from Porsche..............
Old 12-18-2012, 10:37 AM
Features - The new Cayman - All Cayman Models - Dr. Ing. h.c. F. Porsche AG
Thanks for the clarifications.
Ron
2012 Cayman S Black Edition #384/500
2007 Cayman (2007-2011)
1974 911 (1985-1995)
1969 912 (1981-1985)
Old 12-21-2012, 05:44 PM
