Guest
Posts: n/a
The onboard computer needs to know that the car is on a dyno. The front wheels sensors have to be bypassed or the car won't run correctly. Not sure what software you need for this.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Dyno Testing - 986 / 987 |
You will have to disable traction control, if equipped, other than that it should be OK to run. A warning light for the ABS will be set, but once you drive the vehicle the light will go out.
- Nick |
