I am looking to purchase a 2002 Boxter S with 131,000 miles. Should I assume the IMS has already been changed? What is the life expectancy of a boxter engine? Are there any with 200,000 miles?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The life of an engine depends on the maintenance. If you want to be on the safe side do the bearing
- Nick |
With more than 260k miles on them, yes. With 200k and used monthly on the racetrack.
NO. Also, it's Boxster, not Boxter.
2000 Boxster S, Arctic Silver/Graphite Gray, 6 speed |
Depending on service intervals, a 97-99 Boxster motor can easily go 200K, even with the original IMS bearing. If you don't have a receipt showing it was done, it wasn't.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
You know what assume means? It means make an azz out of you and me!
Ims
LN, provides a special sticker that's applied upon repair. You might see one!
Mine has a LN sticker on the door.
