gunna!! (guest)
Guest
Posts: n/a
when porsche boxster has a blow from the exhaust what could it be? but the blow gos after a bit dont under stand!! so is it just the exhaust????
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-14-2013, 04:08 PM
Nick at Pelican Parts's Avatar
I assume you mean backfire. This could be cause by the cylinder not firing and the exhaust igniting the mixture as it leaves. You could have a burnt exhaust valve. Check compression in each cylinder
- Nick
