WayneD (guest)
Guest
Posts: n/a
On a 987 how far does the transmission need to separate from the engine to drop down. Do you need to remove the muffler completely if you remove the the mounting plate at the back of the trans that supports the muffler? It seems that the 987 has more clearance than the 986 between the trans and the muffler.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-15-2013, 05:56 AM
Nick at Pelican Parts's Avatar
Porsche recommends removing the engine and transmission as a unit. It is much easier this way. However, if you want to remove it with the engine in place, it can be done. You will n eed to pull the transmission back about 8 - 10 inches to clear the engine and associated components.
- Nick
