Boxster help requested - 987 acceleration trails off
Has anyone seen this problem before: 2005 987 base with 102k miles and well serviced, occasionally but sequentially drops acceleration. Specifically, when pulling from a stop light or stop sign, pressing the accelerator does not produce forward momentum or rpms - power just drops off.
Lifting and repressing the pedal a couple of time seems to re-synch engine rpms as normal.
Once I put in some BG44, didn't experience problem for a month, but its back.
Different premium gas doesn't seem to make a difference.
This had been happening 2 or 3 times per trip then no more, until next trip but its happening more often.
A similar symptom is when driving with cruise control on, hitting a large bump or pothole, suddenly CC disengages like I hit the cancel button. Could it be some throttle sensor, since I understand 987s have electric throttle.
Have you heard of this behavior before?
Wayne, by the way, do you still sail?
Old 01-12-2014, 11:15 AM
Sounds like the electronic throttle body is acting up.
You will need to replace the throttle body & get it adapted to the pedal.
Is there any engine light on?
Andrew.
1998 Boxster (silver/ red)
1987 911 Targa (sold)
1975 VW Transporter (sold)
1971 VW Super beetle (sold)
Old 01-12-2014, 12:56 PM
No CEL comes on or has come on.
Old 01-12-2014, 07:44 PM
Sounds like the fuel pump is getting weak. Test the fuel pressure.
Old 01-12-2014, 08:42 PM
Author of "101 Projects"
Wayne 962's Avatar
You can't really tell anything until you pull the codes to see if there is a fuel injection system problem? I would do that first.
That said, the cruise control thing is odd - I would maybe think that it may be as easy as your brake pedal or clutch pedal switch is loose or defective. They are cheap, I would probably replace those first, as the bump, cruise shutting off thing is odd...
-Wayne
Old 01-13-2014, 11:27 PM
